rray;
Not that I am taking sides, but as we all know, back in the 1940’s to the late 1950’s, it was common for spaced planking because that is all that was available.
When cedar shingles were starting to fade out to the onset of the new Product called “Asbestos Asphalt Compound Shingles”, everyone was wild. They “the people” started substituting the cedar shingles for asphalt shingles and co-incidentally installed over the substrate material that was there, which in this case was spaced boards that came from a saw mill run by water and not sized for width to save money, therefore you had the automatic gaps that we are talking about.
Today’s standard for ventilation kind of reads down this line,
*There are two very important questions that must be asked of, and answered by, every construction design-whether it is for new construction, for additions or for renovations: *
*1. How does heat enter the attic, and how can those heat sources be reduced?
2. How does heat exit the attic?**The rule of thumb is that properly vented attic air should never be more than 15 degrees hotter than the outside air. A temperature difference of greater than 15 degrees is an indication of additional heat sources that should be eliminated and/or an indication of poor attic ventilation. *
*Proper attic ventilation is calculated by comparing the ratio of attic floor space to the total amount of “net free air ventilation area.” The most beneficial ratio is 1/150; that is 1 SF of net free air ventilation for every 150 SF of attic floor space. All ventilation sold for this purpose has an assigned “net free air” square footage rating that is roughly the total opening size of the vent, minus the various areas of block-age from louvers and screens. Ideally, the total of inlet air at the soffit will equal the outlet air at the ridge for a balanced and efficient airflow. *
*Figure for a moment of the construction of past buildings with spaced planking and how it was used and no ventilation in the attic. *
*Guess what, Most houses back then had walk-in cold attics for storage, and had vented windows or non-vented sashes for natural light. *
*Since the windows were of single pane and no weather seal, a draft would come in the attic. You could also see the gaps around the chimney flashings and feel the breeze. *
*You could observe the new asphalt shingles or cedar shingles from the attic and also feel the breeze from the exterior wind. *
The gable end walls were constructed of vertical boards and spaces and you could see the black homeasote or celitex board with brick imitation, and could feel the breeze from the end walls.
Run the mathematics and calculations of all the free air coming in to the attic in this era of building and you will find the it most likely exceed the requirement that I have provided above of today’s standard.
This is why that the roofing on my Father’s House lasted for over 35 years without replacement.
Raymond Wand is not off track at all with his statements, but rather you can not relate to the existence of the past Construction techniques, and no one has written a book on this subject that I can find to show you or refer to as Raymond indicated. This is based on observance and past experience with this type of Construction.
It is hard to relate and compare to today’s standards.
Marcel
</IMG></IMG></IMG>
