"Saving Home Energy for Real Estate Professionals" online course
This thread is dedicated exclusively for those students currently enrolled in the InterNACHI online course titled, “Saving Home Energy for Real Estate Professionals.”
Upon successful completion of this course, the real estate professional will:
  • understand the value of home energy inspections for current and prospective homeowners; and
  • be able to provide informative options to help homeowners cut their energy use, reduce their carbon footprint, and increase their homes’ comfort, health, and safety.
And, in keeping with InterNACHI’s commitment to Continuing Education, this course is open and free to all members, and can be taken again and again, without limit.
Students are free to pose questions and comments here and join in the conversation with other students. The thread will be monitored by the course instructor.
Contact: Director of Education, Ben Gromicko ben@internachi.org
Other inspector training courses: www.nachi.org/education.
To find a Certified Home Energy Inspector™, visit http://www.inspectorseek.com/.
Thank you.
There are a variety of ways to save energy and save money. One way that I saved energy was from using information in this course. I cleaned the filter in the wall AC and now I have had to turn the temp setting from 60 degrees 70 degrees because it got so much cooler!
The article I chose is : 10 Easy Ways to Save Money & Energy in Your Home
by Nick Gromicko, Ben Gromicko, and Kenton Sheppard.
Some of the ways the article suggests to save energy is to get a tankless water tank or to use incandescent light bulbs.
Programmable thermostats can trim about $180 a year from your energy bill by automatically reducing your heating or cooling when you need it least. Some thermostats tested by Consumer Reports were easy to set and use but others were so complicated that you might end up spending more on energy, not less. Consumer Reports unbiased thermostat reviews will give you honest buying advice that you can trust. Use our thermostats buying guide to discover the features that are most important to consider when looking for the best thermostat. We also provide unbiased thermostats ratings to help you choose the best thermostat for your needs.
The chimney should extend at least 3 feet above the roof surface it penetrates and 2 feet higher than any roofline or other obstacle within a horizontal distance of 10 feet. Taller chimneys make more draft, but chimneys exposed to outside cold don’t. See our section on chimneys. A leaky chimney can cause all sorts of problems which require costly repair. … The flashing is sheet metal installed for the purpose of ensuring that the connection between the chimney and roof is watertight, but the effectiveness of flashing eventually expires. The barometric damper is used to control the draft inside a boiler. It is installed on boilers that use a Category I vent. To understand how the barometric damper operates, we need to understand what draft is. We all know that when air is heated, it will rise. Hot air is less dense than cool air and it weighs less. This is what allows hot air balloons to rise and float above the earth.
Customer Reports fair-minded indoor regulator surveys will give you genuine purchasing guidance that you can trust. Utilize our indoor regulators purchasing a manual for find the highlights that are most imperative to Professional Essay Help UK consider when searching for the best indoor regulator. We additionally give fair indoor regulators evaluations to enable you to pick the best indoor regulator for your requirements.
what an amazing post admin thanks for this.
https://vidmateforpcwindows.com/
https://vidmateforpcwindows.com/2017/10/vidmate-for-pc-free-download-windows.html
http://www.tubemateforpcfree-download.com/
http://www.tubemateforpcfree-download.com/2017/04/tubemate-for-pc-free-download-2017-windows-7-8-10-xp-Mac.html
http://www.operaminiforpcfreedownload.com/
lhk l hlh jlhghg hj u
Ethics characterize individual character and allude to the convictions that a man rehearses when he collaborates in individual and social connections. The direct showed by the individual in individual social practices gives a right assessment of his ethics. Ethics distinguish the way a man lives. assignment help - AustralianEssay. Morals are the codes or guidelines of lead anticipated that of the gathering would which the individual has a place.
Gesture App Lock
App Faker
Pattern App Lock
FingerPrint App Lock
Speaks out the incoming contact name from call](http://www.uniqsofts.com/callernameannouncer/)
Speaks out the incoming contact name from message](http://www.uniqsofts.com/callernameannouncer/)
Speaks out content you copy to clipboard](http://www.uniqsofts.com/callernameannouncer/)
shake to unlock](http://www.uniqsofts.com/power-button/power-button/)
Yes, I do agree… nowadays we all want to save some money for future…using the best things in the home can actually help you to save some good money… for example if you use best Pellet Stove you can actually save money read this article to know how a best Pellet Stove can help you to save money… so in order to select the best Pellet Stove read this guide. thanks
Saving is what we should teach student from the beginning. As you see in the current scenario of energy crisis all around the world it’s become as vast as we used lots of energy but we don’t save any in return. The student who is enrolled in bachelors degree online, we teach them to save energy as well if fewer resources are used then we have many to save for the future. Its program we should launch globally.
hello
Ready to get my course work
Hello…I;m ready to learn this.
I’m ready to start this course
I’m Beginning the course.
