I call out TPR extension pipes that are more than 6" above the floor for water heaters.
My client listing her home just had this water heater installed and the extension pipe was about 12" above the floor so I called it out. She called me back to tell me that her plumber said the code is between 6 to 18 inches above the floor.
Is there any situations where that is correct? This is the first I’ve heard of that.
Maybe you’ll need to check with your local jurisdiction. Some jurisdictions write their own rules. I’ve always seen the 6" restriction as you mentioned.
