On my inspection yesterday i had trouble finding the test button on this unit. Any suggestions? I have not seen this type of unit before. There must be a way to test it. It was the only one in the home.:shock: Does this count as “destructive discovery”?
I inform my clients that the ionization type detectors have a small radioactive source in them. After 5 years, or so, the detector doesn’t work anymore (the source runs down).
I advise them to write a month and year, 5 years in the future, on the detector and change it out when that time runs out.
Many reports, from fellow HIs who are also firemen, of houses that burned and the detectors never went off. Good battery, but 10 to 12 year old detectors.
Put it in your standard maintenance verbiage. It also amazes the heck out of Realtors (which impresses them and gets you referrals :mrgreen: )
I was taught, the NFPA stance on residential smoke detectors is 10 years or until the manufactures warranty runs out. So if you buy cheap ones, expect to change them every 2 years. As for the radio active source idea, the stance is for both ionization and photoelectric POC detectors.
Are you sure it is a smoke detector? I’ve seen many home alarm systems with a siren installed in the home to ward off intruders after they enter the home. Usually a very loud pizzo type horn device, it looks very much like your picture
