Student Discussion: How to Inspect Fireplaces, Stoves, and Chimneys Course
just started the fireplace portion of thee class
Hi I have just gone through the course, only exam still awaits
Ok here I go! Fireplaces…sonthing very rare in the Valley of the Sun, Arizona. Only two courses left!
A member just sent in a great essay response! Check it out:
View Question
Research & Writing Essay Instructions
This research and writing assignment may take four hours.
In relation to this inspection and writing assignment:
  1. Choose one inspection article from the Library of Inspection Articles or choose one illustration from the Illustration Gallery that directly relates to a chimney stack, a fireplace, a vent pipe or vent connection or vent termination, or a fire extinguisher.
  2. Research and study the article or illustration.
  3. In the box below titled “Your Essay," write an essay that describes what you’ve learned from reading and studying the article or illustration.
  4. Upload and submit an inspection image or the chosen illustration along with the essay.
Your essay must meet the following criteria:
  • It must be written in English.
  • It must be at least 80 words in length.
  • It must be written at a minimum 4th-grade level.
  • It must sufficiently comment upon the chosen article or illustration related to this course's main topics.
  • It must include an inspection image.
This research and writing assignment is very similar to what a home inspector does during a home inspection--researching and studying inspection images and illustrations, studying and referring to and applying a Standards of Practice, taking inspection images, making observations, describing components, determining the condition of those components, formulating opinions, making recommendations to correct (if needed), proposing the implication of not making corrections to a defect (if observed), writing notes, and communicating observations in written form.
Please continue with the course after submitting your essay. If the essay does not meet the criteria, you'll be notified by email to rewrite the essay.
Water damage is the most pressing damage and also the most common damage to homes. Chimneys are no different. With being a roof penetration, chimney water proofing is a must. The first step is the cap, which should have the proper shape to allow water to runoff onto the roof. If water bypasses the cap and runs down the flue due to a defect, than water can damage the flue and get inside the home. Next is the flashing and cricket, which when properly installed, will divert water away from the chimney penetration and toward the gutters, not allowing water to sit and soak into the wall materials.
What kind of damage can be caused by an abandoned and uncapped brick chimney? We have a lot of older homes in this area that used to have wood or coal fired kitchen stoves and the chimneys are often left open and simply stand unused and many have no rain caps at all.
I had no idea how dangerous it was to burn treated lumber and plywood! It’s scary to think how many burn piles and kindling boxes are out there with one or both in them. Are we risking exposure to arsenic by coming into contact with fireplace or stove ashes if this stuff has been burned there? Remember your PPE!
Is it best to review the chimney and fireplace separately or is it better for the sake of time to review the chimney during the exterior portion and then the fireplace once inside of the home? How often during inspections does the seasoned inspector have to return outside and rewalk areas due to findings on the interior? I often found myself looking at things twice as I was performing my reviews for my essays.
Beginning my final course to become a Certified Professional Inspector. How to Inspect Fireplaces, Stoves, and Chimneys course.
I’m here for the my final first year requirement course!
Finally made it to my last course!
Not my last one… 5 more to go after this…
almost there too, looking forward to diving into this course!
Hey, does anyone know if there are sample inspection reports that students have access to? for this course or for any of them?
Thanks!
Hi, @mpeden.
Thank you Ben!
I am starting a new course today.
Hey just wondering if you found that checklist?
You said it
Is it just fireplace vents/ chimneys that need a storm collar around it? Are there other vents that need storm collars or just typically on chimneys?
Just starting on this course. Thanks for putting all of these together!
Halfway through this course it’s very helpful. Chimneys especially were something that always intimidated me. It’s nice to feel prepared.
