Sub panels and grounding
Originally Posted By: smcintire
http://www.nachi.org/bbsystem/usrimages/more/P1010003.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/P10100041.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/P10100021.JPG ]
Originally Posted By: jpope
If it is, in fact, a sub panel (equipment panel) in the same building as the service panel, it’s wrong, plain and simple.
Neutrals must be isolated from the panel box and the grounds bonded to the box. It should be fed by four wires from the service panel (H+H+N+G) or, three wires (H+H+N) in a metal conduit as the EGC.
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
http://www.nachi.org/bbsystem/usrimages/more/P1010005.JPG ]
Your reference would be IRC 3507.2 and NEC 250.24(A)(5) which prohibit regrounding of the neutral after the service, with exceptions for separate buildings.
Jeff Pope
“At JPI, we’ll help you look better”
(661) 212-0738
I’ll be waiting for one of our resident Sparkies to come in and blow holes in my reference and interpretation icon_wink.gif , but as HI’s, that is how we should call it.
Jeff Pope
(661) 212-0738
Jeff, thanks I just never find these correct. It’s kind of like the saying how can so many people be wrong and I am right, just makes me wonder sometimes if I am missing something. thank you.
jpope wrote:
I'll be waiting for one of our resident Sparkies to come in and blow holes in my reference and interpretation ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif) , but as HI's, that is how we should call it.
It works for me
Originally Posted By: Ryan Jackson
Works for me too. Well done Jeff
Ryan Jackson, Salt Lake City
Originally Posted By: bbadger
Jeff, Do you want to be a electrician in Mass.?
Of course you will have to adjust to the white stuff that falls part of the year. ![icon_smile.gif](upload://b6iczyK1ETUUqRUc4PAkX83GF2O.gif)
Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
I don't do well in temps below 60 degrees But thanks for the invite
Jeff Pope
(661) 212-0738
Originally Posted By: Russell Frame
jpope wrote:
If it is, in fact, a sub panel (equipment panel) in the same building as the service panel, it's wrong, plain and simple.
An academic question. What if there are only a few 120v circuits in the sub? Do you still have to feed it with multiple hots?
I would think not. So long as the breakers are on the same side ![icon_rolleyes.gif](upload://iqxt7ABYC2TEBomNkCmZARIrQr6.gif) But that would just be silly, now wouldn't it?
Jeff Pope
(661) 212-0738
Originally Posted By: ddavis
This seems to be old install with a sub panel. This needs to be updated.
Jeff: Typically breakers on the same side would be on alternating legs or phases. Think about a typical 2 pole breaker.
![icon_redface.gif](upload://f7DX2EWhmUfsDapWaYT3oJHMCj1.gif) I knew that. Friggen trick question
Jeff Pope
(661) 212-0738
icon_lol.gif Yeah, I know you knew that. Thats why I had to jump on it before you caught it and edited it. icon_lol.gif
Originally Posted By: Brian A. Goodman
Steve,
They can easily convert that panel to two bars (1 neutral, 1 equipment ground) by removing the metal jumper bar between them. As Jeff noted, the bonding of the enclosure must be on the equipment ground bar, not the neutral bar.
Seperating the wires won't be too tough either. Getting the 4th wire in for the equipment grounds will be the hard part.
Originally Posted By: jpeck
Brian A. Goodman wrote:
Steve,
Brian,
I will re-phrase that for you.
They can easily convert that panel to two bars (1 neutral, 1 equipment ground) by REPLACING the metal jumper bar between them with the plastic bar made for that purpose.
Jerry Peck
South Florida
Jerry,
I’ve never seen a plastic bar made for that purpose. The only reason it’s there to start with is to provide a conductive path between the two bars, it serves no other purpose that I know of. Take it out and you’re done.
