Please do not worry about the half support post under the joint in the main beam.
My brother-in-law told me he has seen pictures of houses and that this is perfectly safe. We feel by removing the extra weight of the post, the house will not sink as fast.
However this does leave me with one question…… seeing as I took this picture today, does this mean I should adjust the date on my camera?
David,
Why do you think this is wrong? I’m guessing it was an unfinished basement and they added a wall under the girder/ beam? Correct? Wouldn’t the “new” wall be sufficient for load bearing? Though I am only going by one small picture. Your thoughts…
The top portion (the missing peice) of the post contains holes to macro adjust its height which are more than large enough to run the wires through. The electrician could have easily just ran his wire through one of the holes.
The new wall should be enough support anyway so it really dosen’t matter.
The way I look at; is that the sectional column was to be there for a reason. David mentioned the floors above were wavy. Double top plating would help support the beam along its entire length, imho. Either way if this picture is any indication the person who did the work was not a framer.
On the other hand may be the owner was going to place this sectional column to help stiffen the beam which was omitted during initial construction?
The 2x4s on either side of the half jack post should be bearing on a footing if the post was properly installed originally. Since it’s buried in the slab it appears to be OK. I would have left the temporary jack post in place as the wire had plenty of room to pass by the screw end. Other information may change my opinion but that’s how I see it from the photo provided.
This would seem to be a work in progress. The back side of the wall is already rocked and the top edge is floating. Perhaps this side is to be left unfinished and the other side has a drop ceiling. I would use a top plate but it is not needed in this case.
