I agree Robert, but in this residential building that I see around me, I have yet to see or will see someone that has constructed a slab with bearing walls that would meet this criteria.
The question is will the continuous 2"x4" stud wall bearing on an assumed 4" thick concrete floor replace the capacities of that adjustable jack? Yes.
Architectureally and Engineering concept, no.
This is a residential home of a small magnitude of the necessary designs required to necessitate engineering concepts as you and I are accustomed too would be overlay exaggerated.
This is an existing house, and do you expect that it can be corrected to meet the existing codes and structural capacities of the Engineering World.
The answer is no.
The solution is to recommend further evaluation.
What will the further evaluation unveil is the question?
Well, for starters,
The partition should have a depressed slab. Fine and dandy, but will not happen.
The bearing partition should be framed with a minimum of 2"x6" framing members spaced no more than 24" o.c…
The bearing partion should be framed with a minimum of 2"x4" spaced at 16" o. c. maximum members with double plates at the top bearing and Pressure treated lumber sole plate in contact with concrete.
Most likely will not happen.
Adjustable lally columns are temporary supports anyways, but at the very least could be re-installed.
Is there a 2’x2’ x 10" thick footing under that column? Who knows.
Is the slab bearing on soil capacities of Group IV or Group I of the IRC?
So many unknowns.
What will the Engineer say after seeing all this, would be my question.
Assume that the subsoil meets Group I and assume the slab is of 3000 psi mix and assume their is a 1.4x1.4 x6x6 wire mesh and no depression.
Assume that it is only one story.
That stud wall would be more than necessary.
Is it right? No.
Was it right? No
So how would you assess it?
You think a Contractor could resolve this? No
You think a Contractor could fix. Yes with lots of money. ha. ha.
So you see there is no easy solution or answer to something so simple as supplementing what is missing with the equivalent.
Marcel
