Tested outlets in one room that I got “no display” reading.
The book states that if you get no display it could be hot/ground reverse or open hot/open neutral.
I check the outlets also with my three prong tester and it showed "correct wiring".
Is there any logical reason for this? plugged in an a/c unit and it functioned normally.
Thanks,
Kevin
