The red X marks the spot where the light switch is for the attic light. Is this too far away from the attic entrance, or is this okay?
I would just recommend it being marked as such.
It is fine, IMHO.
I don’t believe there is a requirement for the attic light switch to be anywhere in particular - was mechanical equipment in the attic? if there is no mechanical equipment there doesn’t have to be a light at all.
Up to the 2017 NEC there is no maximum distance required so the switch is perfectly acceptable where it is.
At least there is a switch. On an inspection a few weeks ago, you just had to turn the bulb in the socket to turn it on. Of course, it was a little warm turning it off!
