This week's (June 27, 2023) Tuesday Night Auction: Moisture Meter
This week’s (June 27, 2023) Tuesday Night Auction for Cozy Coats for Kids is a FLIR MR77 Moisture Meter: FLIR MR77 Moisture Meter – Inspector Outlet
All-in-one moisture meter helps you manage your toughest water restoration projects
The new FLIR MR77 is a rugged, feature-packed moisture meter incorporating a pinless sensor and a wired pin probe to capture moisture readings up to 0.75” below the surface of various wood types and building materials. The unit also incorporates a laser-spot IR thermometer, a field-replaceable temperature/humidity sensor, and High/Low moisture and humidity alarms.
Pinless Moisture Sensor
Capture accurate, non-destructive moisture readings up to 0.75" below material surfaces using the integrated pinless sensor.
Wired Pin Probe
Monitor moisture levels in hard-to-reach areas using the FLIR MR77’s external pin probe on 30" wire.
Built-in IR Thermometer
Quickly capture spot temperatures using the non-contact, IR thermometer with laser spot.
Intuitive Display
Large, clear LCD screen simultaneously displays moisture, relative humidity, and air temperatures.
Bluetooth Connectivity
Upload data to FLIR Tools Mobile software so you can easily turn moisture/environmental trending graphs into professional reports.
METERLiNK Compatibility
Embed moisture readings into thermal images from METERLiNK-enabled FLIR IR cameras for enhanced documentation/reporting.
Shock-Resistant
Double-molded, rubberized case is shock-resistant from drops from as high as two meters to bolster reliability and durability.
Rugged Design
Designed to resist contamination, the temperature/humidity sensor is field replaceable to keep the unit in action on the job site.
Rules:
  • Winner will be the post with the highest bid as of roughly 7PM MST (9PM EST).
  • Winner’s company, company logo, and company contact info will be listed/promoted on the Cozy Coats for Kids’ Donors page forever… an added bonus for winning.
Total approximate value of this item with shipping: No clue.
$100 bucks
I bid 150$
$175 bucks
I bid $225.00.
I will go 325
Take it up a notch 350.00
$355. Dollars
$three fifty six :wink:
I’ll take it to 400
425four two five
@tweber2 wins! Congrats! Thanks for bidding, everyone!
You can make your donation online at Donate Coats for Kids - Donate Online | Donate by Mail
Please email Nick your shipping address to [email protected]
I think he was late lol
Congrats! And thanks for the donation.
Nick has staff and himself covered… see around below:
