Scratching my head on this one, I think its fine and the wood dried out and is checking, seeing if I can get your thoughts/feedback. It doesn’t go all the way through, only about 1.5 inches deep in some places and 2.5 in others. its only on 1 side, the other looks fine.
The checking looks fine.
I’ve done a lot of log homes and seen this often.
thanks! this is the first seeing the checking run that much. thanks Larry.
Evening, Patrick. Hope to find you well.
Vertical log home columns checking, up/down wood log home checks, also known as posts or pillars, require inspection for signs of wood rot, wood decay, insect infestation, and general damage.
Here’s what InterNACHI has to say about Inspecting Log Homes as a Certified Professional Inspector.
The wood post appears to be decorative, but you need to see what’s underneath in the basement or crawlspace. There should be substantial support down to the basement floor or exposed footing in the crawlspace. If decorative not an issue just caulk it or leave it there. If it was structural, due to its unsupported height then a few metal bands made to look decorative could be used. Normally I wouldn’t get too concerned, but if it’s structural and it is the only column then it would be a non redundant column, which means loss of that column would collapse the roof. Redundant support means there are other columns to help support the roof if one fails. For example when I designed bridges in the early 80s a two girder bridge is considered non redundant. If one girder goes down the entire span goes down. Now bridges are designed with at least three girders.
Please don’t caulk it. It won’t look good at all later if you caulk it.
Like they did where it meets at the ceiling
Agree, caulking does look bad..
Thanks for everybody’s help
