Manufactured and mobile homes:
The course covers the following categories:
Introduction
Mobile vs. Manufactured
8 x 40 or 320
1976
HUD’s Role
Sizes
Transporting
Foundation
Level
Securing the Home to the Foundation
Inspection
Utilities
Section 1: General
1.1 Scope
1.2 Definitions
1.3 Data Plate
1.4 Serial Number
1.5 Certification Label
Section 2: General Interior Requirements
2.1 Scope
2.2 Definitions
2.3 Light and Ventilation
2.4 Ceiling Heights
2.5 Exit Facilities and Exterior doors
2.6 Exit Facilities and Egress Windows and Devices
2.7 Interior Privacy
2.8 Interior Passages
2.9 Room Requirements
2.10 Minimum Room Dimensions
2.11 Toilet Compartments
2.12 Hallways
2.13 Glass and Glazed Openings
Section 3: Fire Safety
3.1 Scope
3.2 Definitions
3.3 Flame Spread Limitations and Fire Protection Requirements
3.4 Kitchen Cabinet Protection
3.5 Carpeting
3.6 Fireblocking
3.7 Requirements for Foam Plastic Thermal Insulating Materials
3.8 Smoke Alarm Requirements
Section 4: Body and Frame
4.1. Scope
4.2. Definitions
4.3 General
4.4 Materials
4.5 Structural Design Requirements
4.6 Windstorm Protection
4.7 Resistance to Elements and Use
Section 5: Thermal Protection
5.1 Scope
5.2 Definitions
5.3 Condensation Control and Installation of Vapor Retarders
5.4 Air Infiltration
5.5 Heat Loss Certificate
5.6 Comfort Cooling Certificate and Information
Section 6: Plumbing Systems
6.1 Scope
6.2 Definitions
6.3 General Requirements
6.4 Materials
6.5 Joints and Connections
6.6 Traps and Cleanouts
6.7 Plumbing Fixtures
6.8 Hangers and Supports
6.9 Water Distribution Systems
6.10 Drainage Systems
6.11 Vents and Venting
Section 7: Heating, Cooling and Fuel-Burning Systems
7.1 Scope
7.2 Definitions
7.3 Minimum Standards
7.4 Fuel Supply Systems
7.5 Gas Piping Systems
7.6 Oil Piping Systems
7.7 Heat Producing Appliances
7.8 Exhaust Duct System and Provisions for the Clothes Dryer
7.9 Appliances
7.10 Venting, Ventilation and Combustion Air
7.11 Instructions
7.12 Marking
7.13 Accessibility
7.14 Appliances: Cooling
7.15 Circulating Air Systems
Section 8: Electrical Systems
8.1 Scope
8.2 Definitions
8.3 Power Supply
8.4 Disconnecting Means and Branch-Circuit Protective Equipment
8.5 Branch Circuits Required
8.6 Receptacle Outlets
8.7 Fixtures and Appliances
8.8 Wiring Methods and Materials
8.9 Grounding
8.10 Outdoor Outlets, Fixtures, Air-Conditioning Equipment, Etc.
8.11 Painting of Wiring
8.12 Polarization
Section 9: Foundation
9.1 Basic Requirement
9.2 Chassis Removal
9.3 Underfloor Ventilation
9.4 Separation From Ground
9.5 Site Preparation
9.6 Erosion
9.7 Site
9.8 Vapor Retarder
9.9 Connections
9.10 Flood Resistance
9.11 Egress Requirements
Section 10: Standard Set Foundation
10.1 General
10.2 Frost Line
10.3 Footings
10.4 Block Piers
10.5 Block Pier Caps
10.6 Block Pier Shims
10.7 Block Pier Wedges
10.8 Prefabricated Piers
10.9 Support Requirements
10.10 Marriage Line Supports
10.11 Anchoring
10.12 Ties
10.13 Spacing
Section 11: Permanent Foundation
11.1 Content
11.2 Frost Line
11.3 Footings
11.4 Block Piers
11.5 Block Pier Caps
11.6 Block Pier Shims
11.7 Block Pier Wedges
11.8 Prefabricated Piers
11.9 Support Requirements
11.10 Perimeter Supports
11.11 Marriage Line Supports
11.12 Piers
11.13 Location of Supports
11.14 Height of Installation
11.15 Permanent Foundation
11.16 Foundations for Existing Home
11.17 Basement Perimeter Support
11.18 Grading
11.19 Drainage
11.20 Anchoring
Section 12: Accessory Buildings and Structures
12.1 Underfloor Space
12.2 Skirting
12.3 Underfloor Ventilation
12.4 Underfloor Access
12.5 Foundations and Ground Level Access
12.6 Carports and Awnings
12.7 Porches
12.8 Attached Garages
12.9 Decks, Porches, Landings, Stairs, Ramps, and Guardrails
Section 13: Resources
