Originally Posted By: ajalowsky
Fitting to the weather up here today!
Originally Posted By: jmurray
“A little less conversation and a little more action”!
Originally Posted By: tallen
I have put the past behind me,
where , however, it now sits, making rude remarks.
| tallen wrote: |
| What about a gas -pack???? |
"A little less conversation and a little more action"!
Originally Posted By: Aimee Jalowsky
Originally Posted By: jwilliams4
"not just an inspection, but an education"
Originally Posted By: gporter
Gary Porter
GLP’s Home and Mold Inspections LLC
Orlando, Fl 32828
321-239-0621
Originally Posted By: lfranklin
| Quote: |
| 2.5. Cooling
I. The inspector shall inspect: A. The central cooling equipment using normal operating controls. II. The inspector is not required to: A. Determine the uniformity, temperature, flow, balance, distribution, size, capacity, BTU, or supply adequacy of the cooling system. B. Inspect window units, through-wall units, or electronic air filters. C. Operate equipment or systems if exterior temperature is below 60 degrees Fahrenheit or when other circumstances are not conducive to safe operation or may damage the equipment. D. Inspect or determine thermostat calibration, heat anticipation or automatic setbacks or clocks. E. Examine electrical current, coolant fluids or gasses, or coolant leakage. |
| Quote: |
| 65 to be safe |
Originally Posted By: rdawes
Originally Posted By: jpope
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: gbeaumont
Gerry Beaumont
NACHI Education Committee
e-mail : education@nachi.org
NACHI phone 484-429-5466
Inspection Depot Education
gbeaumont@inspectiondepot.com
"Education is a journey, not a destination"
| gbeaumont wrote: |
| Jeff, which national standard are you quoting ?
Regards Gerry |
Jeff Pope
(661) 212-0738
Gerry Beaumont
