This is a new home, townhouse. this valve is mounted above the hot water tank, tank has a standard TPRV, this looks like a shutoff with a drain, drain line runs into the drain pan, is it a pressure relief as well? Can anyone tell me more? Lucky my client didn’t ask!
Not I. Skipped right past it. I don’t usually click links without descriptions (not a critique, just a habit), else I would have known you already had it covered down inside the .pdf.
In theory, a relief valve set at an appropriate pressure would work.
However, you then have have 3 problems. You now have to deal with
sending the released water somewhere. It wastes water. And the
valve could eventually fail to close completely. An expansion tank
is the better solution, which is why it’s used.
I did an inspection yesterday and water was flowing at a rate similar to an AC condensate discharge out of one of those valves. At what point is it a problem? How long should the water flow and how often???
