jweinberg
(Jeff M. Weinberg)
August 25, 2006, 3:42am
Newly installed brand new gas furnace
My cheat sheet says that the age convention on York HVAC systems is:
Year of make indicated by 3rd letter in the serial number.
The serial number is: W0A5480548
This only has 2 letters…
I’m thinking the 48th week of 2005.
Anyone care to confirm my assumption???
rray
(Russel Ray)
August 25, 2006, 11:19am
2
jweinberg:
Are you positive about the first four digits? I’ve seen R and A look alike before, and R would be 2006. There are a lot of "48"s and "5"s there, aren’t there?
jweinberg
(Jeff M. Weinberg)
August 25, 2006, 2:20pm
3
Looks like an ‘A’ to me. Here is a picture…
rray
(Russel Ray)
August 25, 2006, 3:26pm
4
And if one compares the second digit of the serial number to the letter “O” in “Order,” it’s obvious that the second digit is the number “0,” so we have letter-number-letter-number.
Interesting.
bwiley
(Blaine Wiley)
August 25, 2006, 4:06pm
5
Are you sure that is not the serial number to the coil pack, rather than the furnace?
jwilliams4
(Jae Williams)
August 25, 2006, 4:15pm
7
Since 2005 models have a letter-number-letter-number configuration. (SN: W0E5195159)
W *=city of manufacture 0 =third digit of year E =month 5 =fourth digit of year*
(Wichita) 200 -? May 2005
W0A5480548
In this case it’s Witchita Jan 2005
jweinberg
(Jeff M. Weinberg)
August 25, 2006, 10:25pm
8
I’m pretty sure it wasn’t…
Good idea though…
Jeff
jweinberg
(Jeff M. Weinberg)
August 25, 2006, 10:27pm
9
jwilliams4:
W0A5480548
I’ll believe that Jae… Thanks!!
How did you know about this new serial number aging convention for York???
dvalley
(David Valley, License #566 - CMI)
August 26, 2006, 2:06pm
10
Jeff,
I believe Blaine is correct.
Most Furnace data tags are glued to the inside of the cabinet (not outside).
The tag you posted appears to be on the exterior lower portion of the evaporator cabinet. Which is a clear indication that this is the manufacturers info. for the Evaporator.
Did you look inside the cabinet?
jweinberg
(Jeff M. Weinberg)
August 26, 2006, 2:55pm
11
dvalley:
Jeff,
This was inside the cabinet…right above the burner and right below the induced draft fan.
