Inspected a 126 year old stone foundation in south central missouri. The bank and buyer had some concerns about water intrusion in the old stone foundation. Fortunately for me by the time I could do the inspection it had rained several inches. The soil type was Silty Clay over Silty Clay Loam, which can hold up to 3 inches of water for every foot of this soil type like a sponge. The small soil particles sizes trap the water through adhesion (water to soil) and cohesion (water to water).
Here is my recommendations to the buyer:
If you choose to reduce the water intrusion into the basement, I recommend the following approach: Given the soil type and elevated perched water table, maintaining positive drainage away from the foundation walls can help reduce soil moisture levels. However, lowering the water table below the basement floor would likely require a French drain (also called a curtain drain) system.
A French drain system would consist of an excavated trench 18" to 24" wide, extending to a depth below the basement floor. A 4" to 6” perforated PVC pipe would be positioned at the trench bottom and backfilled with ½" clean aggregate. The aggregate and pipe would be wrapped in geotextile fabric to prevent soil fines from contaminating the drainage aggregate. Exposing the aggregate at the ground surface along the back of the house would help intercept surface water runoff. Finally extend a non-perforated PVC pipe that would discharge to daylight, sloping toward the driveway.
Should you elect to install a French drain system, I recommend contacting Allgeier, Martin and Associates, located at 112 W 8th Street, Rolla, MO (573-341-9487). Their experienced hydrologists can assist with system design and specification.
Here area a few photos:
Photo 1: Visible seepage, actually it was actively running down the wall in at a few locations
Photo 2: Visible seepage
Photo 3: Soil was being sucked down into the basement
Photo 4: Parging cracked due to external wall pressure
Photo 5: Hydrostatic pressure pushing soil up throught the floor cracks
