A/C line set through roof vent.
I understand that routing this line-set through a roof vent compromises the vents ability to vent but is this a serious defect requiring remediation? This is a 1970 house in Irvine Ca.
Are you sure you understand what is going on there?
Hazard .
Yes defiantly not allowed needs to be changed by a Qualified Electrician
Electrician??? That’s a line set Roy…refrigerant lines.
I think it’s fine BTW. I don’t think that is a plumbing vent, and if it was, there would be no way to get the lines to the unit.
Thanks I goofed I still do not think it should go through a vent .
I did not look close enough. AC line to me was Electric , Not Air Conditioning
It’s more likely a pitch pan…very common.
Some may understand it more like a pitch pocket. Depending on the area.
Same thing I guess.
http://www.homedepot.com/p/Master-Flow-4-in-x-4-in-Pitch-Pan-with-3-in-Hole-in-Bottom-Soldered-PPH4X4/205430357
http://www.portalsplus.com/roof-flashings
