About Hvac inspection
Hello
Home inspectors are require to inspect the return boxes and supply boxes insulation?
Are require to report air leak as correction or describe or monitoring?
My recommendation, review your state’s standards of practice provided you are in a regulated state.
If not in a regulated state, review this. You will answer your own question right away.
Once you understand the minimum requirements, then a good discussion about exceeding these requirements can resume.
Where are you located?
Are you asking as an Inspector or about an inspection you had?
Home inspectors primarily do visual-only inspections. If the inspector observes HVAC ducting that is missing insulation, they should report that as a defect requiring correction. Other than a gaping hole in the duct, an air leak typically cannot not be detected visually and requires specialized equipment and training, so is therefore well beyond your typical home inspector’s expertise and scope of services.
Evening, Mohammad. Hope to find you well.
Welcome to the InterNACHI message board community.
We visually inspect and describe what we can see. Observation:
We recommend corrective measures when required. Recommendation:
We can not detect what we can not observe. Limitation:
Respectfully, your HVAC component narratives need sharpening.
Supply vent. Where conditioned air is blown into a room or space.
Return vent. Where conditioned air is pulled back into the HVAC system.
Ductwork. The network of channels for conditioned or non conditioned air.
Plenum. A large box or volume that connects the HVAC unit to the ductwork.
It would depend on where the OP is located regarding the bold above. For example here in Texas we are required by our licensing authority to perform an actual operational test of the units and report on that condition as well.
As for the insulation on supply and return plenums that would be something here in Texas we would be required to inspect and report on (if an issue exists) if these plenums are accessible and/or visible to us.
Luckily for us our Texas licensing authority has not required us to inspect and report on air leakage in the duct system itself unless the duct system component leaking was accessible and observed to have openings. Of course the way our licensing authority works it would not surprise me if that changes and we eventually are tasked with checking for duct leakage. So sad!
So again it would depend on where the OP is located as to what the answers would be.
