Some AC units require max. fuse or circuit breaker size of 25 amp. With 25 amp. disconnect fuses and #10 wire, is a 30 amp. breaker in the panel box acceptable?
Question #2: With an AC unit requiring max. fuse or circuit breaker size of 25 amp. is using 30 amp. disconnect fuses, #10 wire, and a 30 amp. breaker in the panel box acceptable?
Thanks.
