After 500+ inspections, I’m seeing the same failure patterns over and over — are you guys seeing this too?
After reviewing more than 500 of my inspections across Memphis and West Tennessee, a pattern started to stand out:
Most homes don’t fail in unique ways — they fail in clusters.
Drainage issues showing up alongside foundation movement.
Roof defects tied directly to attic moisture.
Minor electrical issues pointing to broader system neglect.
It’s rarely just one defect — it’s how systems interact.
I documented a more detailed breakdown of what I was seeing here:
Curious if others are seeing the same thing in their markets.
Are your inspections trending toward isolated issues, or are you seeing these same “clusters” of problems?
Definitely a pattern here too. Mostly related to construction defects. Most commonly installation issues. There are thousands of homes in this area with improperly installed roofs, when big wind events occur the issues shine brightly casting an an ugly shadow of many homes, often entire neighborhoods. HVAC, electrical, plumbing and building envelope issues are very common here too.
Every time!
I didn’t read your entire report, but I did read your executive summary and the closing. I think you have arrived at the crux of what a home inspection should be. It’s not just a list of defects as the InterNACHI SOP would suggest.
A home inspection is an assessment of the condition of the property, both in individual systems and components, and in the entire home as a system. It’s the very reason that I do not offer partial inspections.
Naturally, the defects will be clustered together by major systems/components, as defined in your SoP. Each major system/component has recurring issues. Hence, the popularity of canned narratives. So yes, I see the pattern repeat itself daily.
Let’s not forget the obvious… “Builders”!
I didn’t read your ‘report’ either, (yet), but I wonder how these “clusters” are grouped together by the Builders and the defects they tend to present?
It ifs fairly common to find the same defects in homes built by the same Builder(s)!
How many primary (Big Box) Builder Companies are located within your primary inspection service area?
Something to think about.
I appreciate that — that’s exactly where my thinking has been heading.
The SOP does a good job of defining minimums, but in practice, the issues rarely respect those boundaries. What shows up in one system usually has roots or consequences in another.
That’s really what led me to start looking at these as patterns instead of isolated defects.
I think that’s also where partial inspections can get tricky — it’s easy to miss how interconnected everything is when you’re only looking at one piece of the house.
For that reason, I generally try to avoid limited-scope inspections unless it’s a follow-up or reinspection. The only true “partial” inspections I routinely offer are things like deck inspections or HUD foundation certifications, where the scope is clearly defined and the reporting is built specifically around that system.
Otherwise, it’s hard to separate one component without losing the bigger picture of how the home is actually performing as a system.
That’s a good point — I’ve noticed the same thing with installation quality being a big driver.
What stood out to me is how those install issues don’t stay isolated. A roof problem turns into an attic moisture issue, which then starts affecting insulation, ventilation, even framing over time.
It’s almost like the initial defect isn’t the real problem — it’s how long it goes uncorrected and what it connects to.
Interesting you mentioned entire neighborhoods too. I’ve seen similar patterns where the same construction practices show up across multiple homes, and the failures follow the same timeline.
That’s a great point — and I’ve definitely seen that in my own observations as well.
There are certain areas where the same defects show up over and over again, which makes it hard to ignore the builder or construction-side influence.
I haven’t broken it down that far in the data yet, but now that I have my reports more structured and coded, it’s something I’ve been thinking about looking at more closely — especially on a neighborhood-by-neighborhood level.
I think that would give a clearer picture of whether those patterns are tied to specific builders, crews, or broader construction practices in a given area. My guess is we’d start to see some pretty consistent fingerprints if we broke it down that way.
I agree that each system has its own recurring issues, and you definitely start to recognize those pretty quickly.
What stood out to me wasn’t just repetition within a system, but how often the same combinations show up across systems. For example, drainage and runoff issues repeatedly showing up alongside foundation moisture or crawlspace conditions, or roof-edge and flashing defects showing up with attic moisture and exterior deterioration.
That’s really what I meant by “clusters” — not just grouped by system, but recurring patterns in how different systems interact and fail together.
Some of that is influenced by how we structure and report findings, but even within that, the same cross-system combinations kept showing up in a way that felt more consistent than just individual system defects repeating.
I’m interested in the reasoning of your post here. Do you have a specific question as to why Regional defects occur? In your article you mentioned old HVAC equipment. People keep their HVAC systems until they don’t work anymore. If they’re working, they are not your responsibility as a home inspector.
I am assuming that you made this post as a marketing tool. I used to do that all the time here when I was a home inspector. So if you really have a question or concern looking for a specific answer I would like to help out because I have worked in your area and I know exactly what you’re talking about. It’s great you get a lot of replies from your post, it’s good for the internet, but I don’t want to beat a dead horse with more answers when I suspect you understand why these situations occur.
I agree. This all seems very elementary.
No home fails an inspection. There are defects and you are not a code inspector.
Typical home failure patterns, in residential building properties, frequently stem from water mismanagement, structural movement, and deferred maintenance.
I understand where you’re coming from, and I agree that most of the individual issues themselves are pretty straightforward — aging equipment, deferred maintenance, installation quality, etc.
It’s one thing to see those patterns over time in the field, but going through and actually coding the reports made it a lot clearer how repeatable those combinations are — things like drainage and runoff issues showing up alongside crawlspace moisture conditions, or roof-edge and flashing defects tying into attic moisture and exterior deterioration.
That’s really what I was interested in comparing — whether others are seeing those same cross-system patterns in their markets when they step back and look at their reports collectively, and whether there are any regional variations in how those systems tend to break down.
I get what you’re saying.
I was using “fail” more in the sense of how building components and systems break down over time, not in terms of passing or failing an inspection.
What I was getting at is that defects rarely show up in isolation — the same combinations tend to appear together across systems, which is what I meant by clusters.
I agree — that lines up pretty closely with what showed up in the reports.
Water management in particular kept coming up over and over again, and a lot of the other issues seemed to trace back to that in some way. Drainage and runoff problems showing up with crawlspace moisture, exterior deterioration, and even some of the longer-term structural-related concerns.
A lot of the findings weren’t catastrophic on their own, but they stacked together and started affecting multiple systems at once — that’s really what stood out to me going through the reports.
