I can’t wait to see the results here ![]()
At least they do not call it a home inspection.
Interesting . Has anyone used them ? Are they a professional quality?
Hi Brian, We built this specifically for property condition reports — move-in/move-out, pre-listing, investment due diligence. Upload your photos, the AI documents every room with damage findings, severity ratings, and repair recommendations. Full PDF report in under 2 minutes instead of 2 hours. First report is free — try it at condition-report.com and see for yourself.
Eric — absolutely. Professional quality reports that hold up for landlord-tenant disputes, insurance claims, and real estate transactions. Upload your photos, get a full room-by-room report with damage classification, condition ratings, and photo evidence in under 2 minutes. Fast, reliable, and saves you hours every single week on report writing. First one’s free — go run a report at condition-report.com and judge the quality yourself.
Also, this tool is excellent on mobile, I suggest using it on your mobile, will have the whole report done in around 2-3 minutes. Happy to demo.
I’m not impressed. The report is limited to 12 “rooms”, it is more like sections. I actually had to get rid of a section, which left 11 sections, in order to get the report to generate. Each “room” or section can only have 3 photos each. Very limiting.
Not very intuitive. I uploaded a picture of a flex-drain, it thought it was the back of the toilet. It’s not InterNACHI SOP compliant since it clearly did not call out the baluster spacing. It thought the large brackets on the basement were electrical receptacles. It thought the water heater had a “clear plastic collection pan” under it.
Inspection report .pdf (12.2 MB)
Another note: if you open the link in your browsers private mode, you can probably get as many “1 free reports” as you want.
For those that can’t keep up with all the threads and posts made by the Vendor…
Thanks for taking the time to run a report and share detailed feedback — that’s genuinely helpful.
A few quick responses:
Room/section limits and photo caps — You’re right that the current free trial has constraints. The paid tiers (Single Report, Pro, Enterprise) expand those limits significantly. The free trial is designed to give you a feel for the workflow, not replace your full inspection stack on day one.
AI identification accuracy — AI image recognition isn’t perfect, and I won’t pretend it is. Flex-drain vs. toilet back, brackets vs. receptacles — those are exactly the kinds of edge cases we’re training on and improving. Every report generated helps the model get better. The tool is meant to accelerate your documentation, not replace your expertise. You still review and edit before delivery.
SOP compliance — Condition Report is built for property condition documentation (move-in/move-out, landlord use, rehab tracking). It’s not positioned as an InterNACHI SOP inspection tool. Different use case, different output. If you’re looking for full SOP inspection software, that’s a different category.
That’s dumb. If I get a “free trial” from Netflix, they don’t limit how much of a movie that I can watch. You call it “1 free report” but you limit how much you can do. That’s not a free trial, that’s a free sample.
That is probably the worse comparison I have ever heard. A streaming platform free trial to a AI tool for condition reports for move in move out. Listen to yourself are you serious? And yes the demo model is perfect, you tried it and used it. It did great, did its job generated you a report that would take you hours in seconds. You are welcome.
There is that giant chip on your shoulder again. Another self-inflicted wound. At this point, I follow along in eager anticipation. Watching you self-destruct is fascinating.
Just another throw away Artificial Ignorance product. We got plenty of the real stuff running around. Why would i want it artificial?
