I think putty should be called “thermal seal” in a double pane window. This material varies.
We received feedback that Glazing Compound is usually used as the term, but we will include “thermal seal” as another name in the course. Thank you! Image updated.
You’re right, the glazing compound is material where the glass meets the window frame. Looks like I misinterpreted what the arrow was pointing to.
