Apparently you lost some sleep over this and possibly missed the opportunity to do some inspections, maybe make some money. Maybe things are slow over at PSI? But I do appreciate your feedback minus the sarcasm.
Yes the zip level is a tool and only a small part of the bigger picture. At this point I am simply scanning your replies. Not out of any disrespect for your extensive efforts, but simply because I have a schedule to keep and it is busy. Did I miss your answer to my question about what instrument you are using to ascertain the possibility of a foundation issue?
“Call out” was not the right term. I believe I misled you into thinking I “Call out” any foundation with more than 1.5" of deviation. Actually I attempted to clear that out. the measurement is only one piece of evidence. Others are Differential veneer wall cracks <¼”wide. Extensive sheet rock cracks over doors, windows and ceilings. Cracks in the foundation wider than ¼”. Trim and siding separating from the structure. Windows moving out of alignment between the frame and wall. Sticking or out of square doors
Separation of counter tops and cabinets from the structure. Sometimes the other evidence points likewise to the same conclusion.
I always advise that the client can and should seek the advice of a professional engineer to address any concerns they may have.
I’m not trying to make a secret process. I have been open about it. 32 measurements on the foundation the reference is where I zero the zip level out. Apparently you missed the relevance I tried to make by point out the idea of measuring from the stop sign on the street corner. All measurements are referenced to a point that is calculated then the results are zero summed. So that you are looking at the lowest point as zero and then all the points of measure are shown from there.
Yes I am working for someone and the equipment is theirs. I asked lots of questions about the method being used and the conclusions that can be made from reviewing the results. But I did not ask for a photocopy of any and all supporting documentation. I am seriously considering a zip level in my set of tools as I do see value in it. Admittedly it is better to have a baseline from sometime after the slab was poured and cured. Now that would be a great subject of discussion.
I am very careful to explain to my client that I am using the tool for my own analysis and that it is a small part of a larger picture. I am careful to point out that they seek advice from an engineer regarding concerns they may have and that I have no way of telling if what I am seeing now is what I would have seen in the past as I have no baseline to go by.
No doubt about it. Without a baseline is it useful? Now there is a question worth considering. I think it is. I believe it would be a far stretch to use the results to help formulate an “engineering opinion” but I think it can help me to determine what my opinion is.
Yes I have done a few of these or worked with someone in doing them. Maybe about ~30 and probably have seen six that showed greater than 1.5" were those “called out” as deficient? Nope, I also use another instrument. My eyeballs.
You know honestly I think it would not be a bad idea to require a baseline slab measurement following some agreed upon, standardized process. Maybe a third party to do the slab analysis I’m thinking a lot could be learned from this. It is a shame that it is not.
