I was inspecting this home in North Dakota and came across this attic covered in black plastic. I believe from what I can see that the underside of the roof has been sprayed with foam insulation. I also believe that the house had a fire in it at one time and has been rebuilt. My concern is will this black plastic cause issues with moisture since it can not breathe. Thanks. GDS
Thanks for the reply. I did call out the vent stack. As far as any issues I couldn’t see anything as they were pretty good at covering everything with plastic.
The other concern is are they trying to cover something up.
No I could not tell. I did call out the fact it should have a cover on it.
jdeoliveira2
(John Paul de Oliveira, GB-2 #86934 / AB #44580)
12
In addition to condensation, a small roof leak’s moisture damage will likely increase both in size and duration when the moisture is effectively trapped in the space between the plastic and roofing membrane.
That is a good point. I will pass that information along. Thanks
jdeoliveira2
14
That non standard installation, imo, has no practical application. If someone can think of a possible benefit of the black plastic let me know. I can think of a few, really negative, downsides.
I have seen a small attic space that had been covered in (clear) plastic. The incorrect thinking was that it would make the space below warmer. The whole area became moldy, and this was in a semi arid area. I have also seen a similar situation that facilitated a rodent infestation.
Personally, and professionally, I would recommend removal of all that attic plastic, and it be re-inspected before closing.
