Baseboard heat in closet
(Ethan Goodkind) #1
Hi everyone,
Wondering if anyone can tell me if hot water baseboard heat with exposed plumbing (no register cover) is allowed in a closet. Thanks in advance.
(Charley L. Bottger) #2
I know of no restrictions as to location but the MFG covers should be in place for safety
(Erik Schmidt) #3
Larger closets located on exterior facing walls need to be heated somehow, if they aren’t they can get very cold.
(Scott Frakes, CMI) #4
Ethan
Like Charley indicated above, the cover should be in place.
180 degree fluid flows through that copper pipe. Very hot to the touch.
In addition, the cover/damper provide the avenue for convection (air flow), to properly heat the space.
(Michael Larson, WI Lic. # 1672-106) #5
180?
No system I had ran that hot. More like 120.
(Larry Kage, CMI) #6
My older fin type hydronic baseboard system ran ~ 180, but I suppose they are adjustable with different loops usable but I don’t have the experience in this like Scott Frakes.
403 Forbidden
(I don’t know why is says “Forbidden” but it works just fine.)
Scroll down to figure 1.
Loop system hot-water heating Q&A
8th question down.
But, I do think the temps are coming down because of the safety factor like Mike alludes to.
(Charley L. Bottger) #7
Guys hydroponic temp can be set at anything controlled by a thermostat, no sense in starting argument over nothing
(Michael Larson, WI Lic. # 1672-106) #8
So can hydronic :wink:
(Stephen W. Stanczyk, WA License #221) #9
Yep. Depends on what you are growing in your closet. :wink:
(Larry Kage, CMI) #10
LOL!
(Larry Kage, CMI) #11
I think that would be hydroponic…:slight_smile:
Oh, I see that is what red hat wrote…
