So is this thread to become a pissing match to see who can belittle someone more and more with each post? I am trying to understand why people would assume something about me without knowing? What would make you say I am being sued by a client? I work on my own properties when it comes to rehabilitation. For some reason it appears you guys are bitter about something and are taking it out on me for whatever reason? I came here for help not to be treated like a child. I took the time to write a well detailed post, took the time to take good pictures to come up with a legitimate plan to correct my issue. I would also like to keep my walls out of water. I live in this house, it is mine. It appears that some of you didn’t even take the time to read it because I clearly stated that is was my basement. Either way, hope as adults “certified inspectors” maybe we can stop the childs play and focus on the matter at hand. With that being said, I do own a skid steer and backhoe. The grade in front is more then adequate. The gutter drainage is more then adequate. I will also reiterate that it is a walkout basement, meaning the grades on the side of the house taper to the back yard. The back yard also tapers down to a creek, which was also stated in the first post. All this combined would lead a person to say, the grade is adequate all the way around. I will also mention again that the one block you see that is damp, is the only block in the house that stays damp year round, even through drought. Why? I have no idea. That block is on my garage side of the house, so I would have to go under my driveway to dig to it.
Now if what I am reading is correct, you guys are suggesting that I dig on the outside of my foundation and waterproof it from the outside? I could do this, but it seems like alot of tearing **** up to fix something that isnt that huge of a problem. Like I said already, the area where you see mold with not studs on the bottom of the brick is an accumulation of over 20 years time from where the rigid foam boards were installed. So one would figure if you took the wall and had a gap between it and the cinder blocks you wouldnt have that issue of mold because their would be room to breathe. I would also have thought that maybe my ideas might be better then ones of using plastic to BLOCK water, which I do not believe in to begin with. I also don’t care who or where you are, below grade their is going to be moisture no matter what you do at some point in time. So what would be wrong with bringing the wall off the ground and wall to prevent that at all times? I guess I am confused with how you guys are acting in your “retaliation posts”. I was under the understanding this was an informative site full of “profressionals”.
I do appreciate the other positive feedback that has been received and will look into it now that I am back to a computer.
And thank you for stating the obvious that decking isnt a structural board, but the reasoning for using it is that it will never rot, seems to make sense to me?
NO WATER NO MOLD! Wall out of water, no mold in wall. Makes sense to me? And like I have already stated, I do not have standing water in my basement, just a dampness of that one brick, and slight dampness on bottom during a heavy rain. Other then that, we are dry as can be, sump pump diverts the water out from under my basement floor.
I am just trying to come up with a reasonable, legitimate way to finish this front wall of my basement so I do not have mold problems in the future. Talk all of the trash you want about whatever you want, but if I wasn’t trying to do this right, why would I be posting on this website? I am a firm beleiver in not passing the problem on to the next guy, but even after I have taken this extra step to make sure to do right, people still want to belittle and talk trash. Lose the ego and help instead of cut peoples idea’s down, it would make this world a much better place.
Again thank you for the ones that have posted good information, it will be reviewed.
