Hello everyone,
Let me start off by saying I have no clue what i’m doing. I decided to finish a rec room in our basement. This is an old house with concrete block walls that were previously painted with latex paint.
I went to lowes and asked a random person about what type of insulation I would need. He suggested faced batt and then asked if I had put up a vaper barrier between the wall and the frame. I said no but if that is the best way to go I can still do that without too much trouble. Long story short, here is my current setup which after looking on the internet seems to be a terrible one.
I wrapped the back, sides, top, and bottom of my frames with plastic sheets I got from lowes. I have the frames directly against the concrete blocks. I then added the r-13 insulation with the paper facing the inside, and drywall over top. so from inside out I have drywall, frame/insulation, plastic sheet, block wall.
The basement is fairly dry. The few spots suspected of any moisture had drylok applied. There is a ledge about 5 feet from the ground that moves the wall out about 4 inched to the outside, so the upper two feet of the frame is not touching the wall directly leaving 4 inches of space between the wall and frame.
I am kicking myself for just trusting someone and not doing any other research. Do you see any way to salvage this setup or do I need to remove the drywall and the vapor barrier. If it is possible to leave the frame against the wall what do you recommend using?
Any help or suggestions are greatly appreciated.
Thank you!
oh, forgot to mention the setup is pretty much the same as this guys youtube video
http://www.youtube.com/watch?v=t-OtAvBMT9k
](http://www.homeconstructionimprovement.com/how-to-insulate-basement-walls/?replytocom=56329#respond)
