See picture:
Grout looks dirty, no evidence or smell of mold.
Shd I express concern in the report ?
See picture:
At the very least you could recommend re-grouting/sealing areas where sealant has deteriorated to prevent water entry behind the wall. If you speak to your client verbally, you could discuss the possible issues, concerns, etc. that could result by not addressing this location.
Good luck.
caulk at tub/tile joint in bathroom need replacement to insure water tight joint…
Thanks…
thanks…
If it is not water tight, it probley will be mold if not now.
Water loves soaking those tiles till loose.
A little Tilex will clean it right up.
