I’ve completed thermal imaging training, but the courses didn’t cover much detail on reporting. Do you usually add a “Thermal Imaging” section within your home inspection report, or issue a separate thermal report regardless of the thermal service being primary or ancillary? Also, what do you consider the “do not miss” items when performing a thermal inspection, and do you follow a specific SOP for consistency? Or do you just report thermal anomalies?
“Thermal Services” are not included in any State or Home Inspection Organization SOP, thus making them an Ancillary Service ONLY, and should never be included within a Home Inspection Report! Also a great reason why you should be charging a FEE for any IR scanning you provide.
Curious… what does your Insurance Carrier for HI and IR say about this subject??
Thank you for clarification on being ancillary only. I found it questionable when my insurance gave me a stand-alone agreement for thermal, “if just performing thermal imaging.”
100%, I definitely plan to charge a fee for this service. But making sure I get everything set up and clarified on before I even offer it.
You need to clarify your coverage with them BEFORE you get in a difficult spot!
Contact them to get their standing (in writing) on coverage IF IR is performed in conjunction with a Home Inspection… DO you have coverage at all, and how your Agreement and Report should handle the scenario?!
I use thermal to verify temps at heat registers. I have found many registers that were disconnected or covered up by flooring. I also use it when testing stovetops and ovens. It produces a better photo to show heat then a standard photo. I also use it for leak verification.
I also use it when checking electric ceiling or floor heating.
All these photos go in my standard report, I do not charge a fee for this.
If I was using it for air leaks, etc, it would be an add-on service and an extra fee. But I do not offer it as a service.
I use IR in a simar way as @wjones18, but not quite as extensive. However, I do not include IR images in my report. Too much is assumed and not understood about IR images - what can and cannot be identified. I don’t want to get into any litigation or conflict that involves IR. I agree with JJ, IR does not belong in a general home inspection.
IR used in conjunction with a blower door to identify energy use issues is another service, but not part of a HI. To do that kind of work, one should have more training and certification besides a NACHI - CE course.
I recommend a scope of work for any ancillary service. You and the client MUST agree on what the heck you are doing. It gets complicated with thermal because the tool has so many uses, some qualitative and some quantitative. It is best to know what you are doing and why you are doing it, then clearly communicate this to the client. For example, some people may be concerned about energy loss while others electrical safety.
I think it depends on what you are doing. A stand-a-lone IR survey, arguably should be a separate agreement and report. But using IR to quickly and accurately determine the effectiveness of the radiant floor heating in the bath, does not require a separate agreement or report. I never get requests for stand-a-lone IR surveys. 100% of my IR work is part of my regular inspection and I do many inspections where I never use my IR.
I agree.
BTW, the Nachi training for using IR is good, but incomplete for serious IR work, The Nachi training gets you to a place where IR is a glorified flashlight. Over and over, I see home inspectors making comments based on incorrect interpretations of what they think they see in their IR. Be ever so careful, with your comments with IR.
From your questions I recommend you attend Infraspection Institute for some real training. Jim Sefferin has written most infrared standards of inspection out there.
He handles how to write reports and procedures for conducting thermal inspections. Don’t waste your time on free stuff, or money on other people’s junk food
