Block pier Shims/Spacers
I have never seen anyone do this type of shimming or spacers before. There is a old (15 yr old house) settlement crack above a door in the master bedroom that I think was caused by this shim being placed vertical and not laying flat.
Whatever the cause, what your pictures show is a really bad idea. Wood shims/spacers - bad. 2x4’s on edge - even worse. You can see in the first picture where they are starting to distort. Only a matter of time before the grain separates and they fail completely.
Just WRONG!
4" space or more requires masonry, I believe.
That’s retarded.
A really smart guy wrote this a few years ago: https://cloversc.org/docview.aspx?docid=25330
Used this today. Thanks for your participation on the forum.
Wood shim adequacy must be evaluated by the engineer of record based on Nation Design Standards for wood bearing provisions and the imposed load at the bearing location. As a structural engineer I would have to determine the load on the beam and convert that to psi on the shim. Wood shims have different load capacity based on species of wood and orientation of the shim. The way these wood shims are oriented and the slope of the wood grain the shims may shear off parallel to the grain. There is an engineering formula called Hankinson that reduces the load capacity based in the angle of the wood grain. The short answer is you would call it out as non conventional and suggest an engineer look at it.
