Bonding or grounding of bird cage?
A realtor I work with frequently, called me and asked if Birdcages must be grounded. Apparently an inspector from out of town claimed it must be. There is, to my knowledge, no electrical power mounted on or around this particular birdcage or water features near it. I have not visited this property. The screens are nylon mesh, not aluminum. Not sure it matters, but that’s what she told me.
I don’t recall ever seeing a grounded birdcage except when an LPS was present. I’ve seen that a few times.
Seems to me that an aluminum frame, bolted into a conductor(concrete) ought to be grounded. Although with our sandy soil, it’s probably got some resistance.
Any thoughts? I did some digging and found no references to a birdcage grounding requirement outside of a few pool exception and/or if it has some kind of electrical service mounted on it.
Well what do you think Mark? What about dog crates? Maybe their food dish?
You do realize I posted this in the Florida section?
A bird cage is a very specific thing here in Florida and it has very little to do with actual birds except perhaps to keep them out.
Are you talking about a lanai screen enclosure?
No, Lanai’s have a roof.
This is a bird cage.
Same thing, screen enclosure.
I’m not in Florida, but being that it’s the lightning capital of the US, and if that’s a metalic frame, IMO, grounding or bonding it certainly couldn’t hurt.
But I can’t say if it’s a requirement or not.
Never heard them called that
I’m not aware of any bonding requirements for the screen enclosure unless it has a pool or spa.
So should the gutters have bonding too? IF they actually installed them!
I agree, additonal grounding wouldn’t hurt. It is grounded. It’s bolted into concrete. It may not be a perfect ground, but it’s a ground.
What I’m after is if there is any requirement for it to be specifically grounded (i.e. a grounding rod somewhere) or bonded to the electric for some reason, even if it doesn’t have electric in it.
I can’t find anything unless there’s a waterfall or pool related or outlet related.
There’s half a million people around me that call it that. Maybe it’s a central Fl thing.
If I lived in Florida, I would bond everything metalic that’s attached to the outside of the house.
Most people around here that have them have a pool and call it a pool cage. I always call it a screen enclosure. :man_shrugging:
It is also an architectural style.
Refers to a specific style of homes designed in the 1950s by architect George Leonard Ely in the Bay Vista Park neighborhood of St. Petersburg.
  • Key Features:
Airy design with large screened-in patios, overhangs, jalousie windows for airflow, and heavy concrete floors.
Some of the homes I’ve inspected have birdcages larger than the home I live in. They tend to have very high ceilings, so Airy is a good description.
The really big ones do have pools, but in this case, it’s just the frame and screen. No pool.
AVIARY is the correct, formal term.
Been doing this a very long time, no one around here calls them “bird cage”.
Maybe it’s the weird vibe from The Villages…
99.9% of people don’t use them for birds, rather to keep mosquitoes out.
^^^ That…
More than just The Villages.
