CCPIA® Inspection Tip: Roof Drains
Rob Claus provides important reminders on what to keep in mind when inspecting roof drains during a commercial property inspection.
Thanks for the pointer, Rob.
The 4th way is to drain off the roof. Frequently done in my area if there is parking lot, street or ground drains.
I concur, Dan. Working with commercial roofing contractors they always removed water with a pump and hose running to the parking lot sewer. Then if a repair was implemented sawdust was used to dry the membrane and torched dry at the end.
