CCPIA Inspection Tip: Window Seals
Join Rob Claus as he provides valuable insights for inspecting windows in commercial properties.
Hey Rob,
In commercial store front there is usually a weep system that would take any water that may get by the intact vinyl (laced in a channel) weather stripping into the metal framing (Which is hollow). Its a design feature. However if it is completely missing the volume of water may be greater then the system is designed for and all bets are off.
