These stains are on the living room ceiling directly below the master bathroom. The tub was filled with water and drained, the sinks were run for 20 minutes, the stall shower was run for 20 minutes, and the toilet was flushed 5 times. After all of that the stains were found to be dry - no other indication of leaks.
Do you:
- just mention dry stains on the ceiling and report your inspection method.
- Call for more testing, as there are no signs of repairs.
- As for a seller written disclosure.
- State that there is no guarantee against future leaks due to no visible repairs.
My feeling is that the tub is not being used and may be the culprit. Filling it up once may not be enough to detect any stains. How would you guys write this up.
