rnewland
(Robert Newland, JR.)
#2
Wire not secured in proper location.
swaskewicz
(Steven C. Waskewicz, CMI)
#3
Wire not secured properly under clamp.
jharrison
(John Harrison, CMI)
#4
Wire should be secured on the opposite side to the bolt
chorne
(Carla Horne, Fl-HI9149)
#5
The ground electrode conductor should be placed between the clamp bolt and the ground rod.
bgromicko
(Ben J. Gromicko)
#6
What the “layman’s” term used to describe the clamp?
What is written/stamped on the clamp?
jevans
(John Evans)
#8
The clamp is called an “Acorn” clamp. Wire should be installed opposite side of the bolt.
dvalley
(David Valley, License #566 - CMI)
#9
Not only is it installed on the wrong side of the clamp, it can be utilized for burial purposes.
wwilson3
(Wayne Wilson, TN 439)
#10
You left your patch n the panel? Just kidding
bgromicko
(Ben J. Gromicko)
#11
