chimney
Originally Posted By: dgiblin
Moved to Members Only Area. Subject: Call back
Originally Posted By: jmyers
Daniel,
That would really depend on how you wrote it up. Did you write it up as, "in need of repair"?
Joe Myers
A & N Inspections, Inc.
http://anii.biz
Originally Posted By: jhagarty
dgiblin wrote:
I reported a problem with flashing around the chimney. The flashing was not visible, as the chimney was covered with tar. .
You reported a Problem regarding the Flashing.
What was your Recommendation for further Review and Repair?
Joseph Hagarty
HouseMaster / Main Line, PA
joseph.hagarty@housemaster.com
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
I recommended a licensed contractor repair/replace as needed for all issues with the flat roof, chimney flashing and vent pipe boots/flashing. I also took moisture readings in these areas during the inspection and did not get any indication of moisture.
