I did a practice inspection today on a 2005 townhouse with a Cutler Hammer electrical panel. In one of the bedrooms the AFCI circuit would trip when I plugged my circuit tester(green one) into it. The yellow tester did not trip the circuit though. Could that be a bad breaker or was my cheap tester causing it to trip? Also two of the other AFCIs did not trip when using the test button on the breaker. Thanks.
Ken, I have the same tester and it does the same thing with that particular brand of AFCI breakers. The first time it happened I didn’t know what was going on until I got to the main panel. Its kind of a pain because you trip the AFCI then have to go reset it and then use another tester. I need to modify my routine to check for those breakers first. Other then that I like the tester.
This is why I carry three different brands of testers. If one acts up, I switch it out for another. Only once have all three had the same issue at the same time.
