Good morning. I read these forums all of the time and thanks for the great info over the years. I had an inspection yesterday and the clearance above a gas stove was only 14” from base of burner to the bottom of the microwave. I have never seen one that close and appears to be an issue for many reasons, but I have not been able to find anything that gives a specific clearance.
Can anyone point me in the right direction? Thanks a lot and you all have a great week!!
Check the installation manual for the microwave. From there you can recommend anything you “feel” makes sense. My pots won’t fit in 14 inch space let alone allow me to open the lid to check on the food goodness.
I believe it’s 30 inches in the international Residential code for combustible materials. Installation shall not interfere with operation of the appliance. If you feel the microwave is installed too closely to the cooktop call it out.
Almost all OTR micro’s list the clearance requirement between the upper cabinet and the range top. And that is typically listed as 30 inches.
They don’t state the minimum distance between the micro and the range top.
As has been posted, look up the specs for the actual appliance in question.
According to the National Kitchen and Bath Association, the bottom of the microwave should be no higher than 54 inches above the floor, which would allow for 18 inches of clearance between the microwave and the typical cooktop height of 36 inches. https://homex.com/ask/how-high-should-a-microwave-be-above-a-gas-range
In this case the allowable clearance is dependent on the listing of the microwave. So while it appears low…and the low clearance is inconvenient…possibly unsafe… the listing (microwave installation instructions) may allow it.
This is from GE’s website:
Over the Range Microwaves and Advantium Ovens:
Over the range microwaves and Advantium ovens require a minimum 66" mounting height from the floor to top of the unit. The 66" from the floor dimension will allow approximately 13" between the cooktop surface below and the bottom, front of the microwave.
All current over the range microwaves and Advantium ovens can be installed over gas cooking products up to and including 5 burner stoves. As long as the 66" minimum from the floor to the top of the unit is followed there will be no performance or warranty concerns.
Note: Over-the-range microwaves and Advantiums should not be installed above any gas range or cooktop that has a combined BTU rating over 60,000 BTUs, not including the oven/broiler BTUs.
