Closets, Water Heaters and Electric Heat Pumps
Originally Posted By: jremas
Let the comments begin!! Thoughts? What would you write in your report?
Does the disconnect serve both the furnace and the water heater?
The water heater supply wire appears to go off into the staircase.
I wonder why the call it duct tape if it does such a crappy job of lasting over time.
It that the TPRV hiding behind the tag? I don't see a drain pipe to take it to floor level or out of the building.
Erby
Originally Posted By: ismetaniuk
This membership was a big waste of my time!!!
Igor
Top To Bottom Inspections
Glen Spey, NY
But Igor, he should also tell them what’s wrong that he recommends those individuals.
What issues did you see that you would make those recommendations is his question.
