I recently purchased a new home from a local builder and noticed a large cold pour joint that runs from the bottom of the side foundation wall up to the top of the front wall near the garage entrance.
The builder is claiming that this is not a concern and it is simply a line. I live in an area of cold climate in Canada and am concerned about long terms issues with moisture / frost. In your opinion is the cold pour joint in the pictures acceptable or should I push back with the builder and bring an inspector or structural engineer?
Yusuf, please see and read these links to help you understand:
A cold pour joint , where successive pours or placements of concrete abut during building construction, are normal but on occasion are leak points that may need sealing or repair.
I’ll request that they seal / repair the area to prevent leaking. I was concerned that my particular case was more severe than normal as some of the other cases I’ve seen while researching online are not as bad / noticeable and still leak.
Looks like the outside wall of the garage area. I suspect the inside area will be backfilled before the garage floor is poured. If that is the case there should not be any problem.
Cheers
