Need help with the age of a Coleman furnace. Is the a website I can access that will help with this? Or does anyone have some kind of reference book that will help with this?
I appreciate the help on this!
This is all I have.
Coleman: Serial numbers prior to April 1992=1st two numbers are month, then year, then series.
After April 1992, 1st two numbers are year, then month, then series.
Call 905-672-0860 if you get stuck.
Thanks for the info!
Scott sometimes this site helps
its usually in the mod for the older colemans, like the presidential models including in the serial number.
I got this someplace, probably here. Might help.
