Looking for input from anyone who may have seen this before or have some insight. Looks as if the top of these two support columns have had water damage from the inside out. The center column is not damaged. Two outside columns have gutters butting them and would appear that the gutter experience high traffic splash from the valley and water splashes over and creeps onto the top side of the column. Do you think the whole column would need to be removed or just the box at the top?
Wayne,
It will be difficult to say from looking at pictures what all will need to be replaced. Report what you see and refer it out to the proper qualified professional for repairs as needed. Until, some additional investigation is done on the damaged areas, you won’t know the answer to your question. Best regards.
Kidding aside, Wayne, those look like masonry columns, so they should be fine.
The hidden damage is in the stucco covered wood framed boxes above the columns. By the time the water starts leaking out the bottoms like that, the damage has been done inside the boxes.
“Stick a fork in it” and the picture is self-explanatory.
It can be repaired, albeit costly. Stucco removed, all damaged wood (likely OSB) removed. Kickout flashing added by the gutters. Then replace it all. Definitely a few thousand to fix that.
It’s one of those home where they spared no expense on some things and went cheap on other things. I would not give you a bucket of pizz for it but hey one mans garbage is another mans treasure.
