Combustion air from attic
Passive combustion air does not do what its told. The opening is dependent on pressure difference for flow to occur. Air flow goes both ways.
I realize how air flows in a building. I have done probably 1500 blower door tests. I am saying that perhaps, just perhaps, things are not always the way they seem to be. You are correct, there is no CMI test. I am a CMI based on 17 years of home inspection experience. I appreciate you trying to make me look stupid, or perhaps inexperienced. Maybe one day I can wear a red hat and be cranky.
Well Brad you came charging in on your white horse like a two pipe C air system was stupid and I became defensive of something that has been used here for as long as I can remember + after Nickie proclaimed what Russell Hensel little Org was a consumer fraud I decided to take a whack again at CMI with all the new 3 year CMI’s now in place I assumed (my Bad) you were one also I apologize for jumping your case so hard I don’t normally do that unless your name is Larson or bushy
Thanks buddy. No worries
Air is a fluid and will move from one area to another based on pressure differences. As air is taken from the room by combustion, a vacuum is created and the air is replaced by attic air. The physical connection essentially makes the room part OF the attic. The limitation is on the size of the opening. Two straws would not provide enough air. A completely open ceiling would be more than enough. Someone has figured out that 2 tubes will work fine. There is sufficient air in an attic to support combustion, most would agree.
We are all waiting for your suggestion to the homeowner/builder/code writers about how it should be done.
Everyone should know that the tubes have to be rigid metal. I sometimes see HVAC flex ducts used. That’s a code violation as the ducts can be compressed in hidden areas.
Who is “we”? Is it the royal we?
I am simply suggesting that perhaps air does not always flow in the direction you hope it will. I have seen this setup fail. It’s not often, but it does happen. Combustion testing is part of my energy evaluation so I take it seriously. Are you telling your client that code says its fine and there should be no issues?
