I am starting to see this product used in My area .
We do not have Termites if our area yet .
I think these forms would be a great highway for termites and other unwanted critters to enter.
Am I missing some thing or are these as good as they say
I promised my self a few years ago that my next house will be an ICF (Insulated Concrete Form) house. There are many different styles with different benifits. In general, they are much better sealed as far as air leakage goes.
I have designed and seen many homes built with the ICF system. I have seen them in my area of southwestern Ontario and observed construction in my teaching sessions in regions such as Edmonton alberta and Val’dor Quebec. Actually many northern communities are now using this because of its ease of use and material cost issues.
Its a great product that permits easy erection and forming of wall systems both above grade and below grade. I have yet to see an issue with termites, primarily because of the way most of these ICF systems are detailed. With a poured concrete and reinforced wall system the wood is generally out of reach of termites.
Above grade the system can be clad with a variety of materials including masonry - they have a ledge block form that provides for such construction. My architectural design class is currently detailing a 3 storey commercial building with a similar type of product.
ICF foundations, and even ICF walls, have become very popular in colder regions of my state.
It generally has no permanent structural value, and I think the same pest/termite precautions related to standard formed conrete walls would apply (e.g. soil treatment, termite shields, etc.).
I inspected one this summer with a lot of water problem in the basement, they’ve changed the weeping tiles previously to solve the problem, it didn’t work, maybe it was not built right
The lot slope was not that good. I would make more research before using this system.
I am curious since ICF construction isn’t really used here on Long Island (common upstate). What are the special termite prevention measures used that vary from the standard soil treatment and sill plate shield provisions for frame construction? And why would ICF construction need special precautions over conventional framing with no food value for the pests?
9.15 and 9.20 of the 2006 OBC effective Dec 31, 2006 deals specifically with ICFs. We were told that 9 3.2.9 applies to ICF just as it does to other foundations that have the insulation added.
See the yellow metal flashing. That is the termite barrier.
Paul Hinsperger
Hinsperger Inspection Services
Orangeville Ontario www.hinsperger.com
RE: Termites
this is a hot topic!!! The ICFA has recently done a full review -you can get a copy through the CONTACT ICFA at www.forms.org
Basically, the code has termite provisions to protect the structure IRC320, and additional provisions regarding foam plastic. IRC R404.4.7.2. However, individual states and location jurisdictions often have their own interpretations. Generally, the goal is to protect the structure from being eaten and collapsing. This can be accomplished by having all structural elements termite proof (ie concrete, or steel), or keeping the critters in the ground where the belong. This can be done with a physical barrier (ie termite mesh), by termite resistant foam, or also by forcing them out to the surface/ daylight. Termites don’t like air or light and it is easier to apply preventive termiticides to reinforce this protective band. ICFs have been used very successfully in termite areas Feel free to contact us for more info. www.forms.org
