Condensate on furnace not going to a drain
Hi guys, new inspector here and this condensate line has me stumped. It seems to be going to the air intake vent pipe. Seems very odd. I can follow it out of the furnace to the pump and then it goes up to the intake. This can’t be a good technique? How do I write it up?
Can you post a picture of that?
Unfortunately I didn’t take a picture of the pump or a bigger view of the furnace
Maybe a condensate drain back to the condensate pump?
Maybe, but where’s the condensate supposed to end up? I couldn’t see a line that terminated anywhere
I’m planning to recommend servicing anyway, so will specify that they should get the condensate line verified for proper installation
Follow the line in your picture down to the floor where the condensate pump typically is. From the consensate pump there should be a drain line tube up to the house DWV line somewhere.
This tube attached to the conduit may be the pump discharge hose.
Ah, I see. Thats likely it. Lesson for me to take more pics!
In a drain. I would write it up.
I also write up all HE furnaces in older homes that drain into cast laterals that don’t have condensate neutralizers installed.
Is that the intake or exhaust vent? The reason I ask and I know all furnaces are different, but mine has the intake on the left and the exhaust on the right. Also, it would seem that you would get more condensation in the exhaust vent as opposed to the intake.
Moving forward, you will want to take better / farther back photos as well. You can zoom into a photo but you can’t zoom out.
Are you sure that’s the intake and not the exhaust? That connection makes sense to me if that’s the exhaust.
It was running and I felt the pipes to be sure. It wasn’t on the warmer exhaust which I also found strange. Would have expected that more than the intake.
you beat me to it :smiley: Especially in long horizontal runs
HE furnaces are condensing units that are designed to receive then expel the condensation to either a drain or a condensation pump. IMO that installation is wrong.
Who was the manufacturer of the furnace?
It looks like the intake, based on how it terminates into the cabinet. Some setups have a drain on the intake also, while the exhaust drains internally through the furnace. If the OP had a picture, the intake drain is like connected to the exhaust drain (and then on to the pump), similar to the diagram below. Or, they may both go to the pump separately.
I’m guessing you did not open up the furnace cabinet to take a look?
I did. I didn’t notice any corrosion or moisture
Thanks! I guess depending on the climate in your area, would depend on the moisture coming through the intake to warrant a condensation drain?
That, and if the installer was able to slope the pipe to the outdoors or not. Sometimes you can’t.
