New home 11th month home warranty inspection.
Roof recently patched in a valley one rafter over.
Drywall is very damp to wet below.
Weather: Rain sometimes heavy last 24 hrs.
Much mold growth in attic
No other area has these water beads.
One more thing why is this message there
“Please Note: This user is a non-member guest and is in no way affiliated with NACHI.”
Thanks for your opinions and please give me a break this is my 1st post.
Look for a exhaust fan or a plumbing vent into the attic .
It could be hidden under the insulation .
Been there found it under the insulation .
Roy Cooke
Does this home have adequate soffit and ridge vents?
If it has soffit vents have they been blocked by insulation?
As you probably are aware both of these can also be a factor in a condensation problem.
Why was the roof repaired on such a new home ? Did the same person who roofed it originally do the repair and then make the same mistake ? More often than not , if the valley is leaking , it could be because the shingles were not back cut.
I know some one is going to say it’s not our job to find out why.
But I find that knowing why makes one a better inspector.
