Condo "fire" wall
Inspected a condo today. It was built in 2005, this is the “fire wall” found at the wall to the adjacent unit. There was a gap between the Block fire wall and the roof, so they filled it with fiberglass insulation…
I’ve seen many plans (and installations) that call for rockwool for filling the gap at the top of a party firewall.
The spray foam is a combustible material. It would be a a no go in my book.
Looks like loose fill fiberglass.
AI disagrees: Is there non combustible spray foam insulation?
AI Overview
Yes, though strictly speaking, no spray foam is 100% fireproof. The industry standard is Class A Fire-Rated or fire-retardant foam. These foams do not easily combust or fuel a fire; they self-extinguish when the heat source is removed. [1, 2, 3, 4, 5]
Here is the breakdown of your options:
1. Fire-Rated Polyurethane Spray Foam (Most Common)
Most professional and DIY spray foams (like polyurethane) are organic and would normally catch fire. However, manufacturers treat them with flame retardants to achieve a Class A (Class 1) fire rating. [1, 2]
  • How it works: It chars rather than burns, slowing the spread of flames and producing less smoke.
  • Products to look for: Closed-cell Class A formulations, such as Akfix Thermcoat Fire Rated Foam or Handi-Foam E-84, which are engineered specifically for wall cavities and rim joists. [1, 2, 3, 4, 5]
2. Cementitious Foam (Truly Non-Combustible)
If you want an insulation that is entirely inorganic and essentially incombustible (like concrete), you are looking for cementitious foam (brand name example: Airkrete). [1, 2]
  • How it works: It is a water-based, mineral foam (made from magnesium oxide) rather than a plastic. It will not burn, melt, or produce toxic smoke.
  • Pros: Completely fire-safe, does not expand upon setting, and can be pumped into existing walls.
  • Cons: It requires specialized professional installation and dries much slower than standard polyurethane foams. [1, 2, 3, 4, 5]
The attic has batts of FG insulation - I think it’s just loose material pulled from a batt of insulation.
Could be. I think they are using it as an air seal.
I probed into the gap and it opened into the center of the CMU. My concern is that smoke and gases will go through. Everything I’ve ever seen is to seal it with fire-rated caulk.
I don’t disagree, but can you confirm that was spray foam used? :thinking:
That is not spray foam. It is loose FG insulation.
The first picture is of spray foam on my end. Not seeing the the loose fill insulation. :thinking:
Here’s a bigger version
Sorry. Maybe it’s my eyes, but I still don’t see any loose filling.
Ok, I do see a a tad bit in the right corner. Does it run the length?
You may need a new ipad or new glasses or both.
That’s not good, you have a valid concern. Fire caulk is a potential remedy. Plans I’ve seen with rockwool insulation typically call for the entire void above the wall to be “friction fitted” with the rockwool.
I couldn’t figure out what started the “spray foam” comments, then went back and realized it does look like foam. But all of that filler is actually FG insulation pulled from a loose batt. And it does run the length of the wall.
I really need you to stop replying to my posts.
Does the block firewall penetrate the roof?
I’m not sure actually. This 1-story condo end unit is adjacent to a 2-story unit. So this block wall would go up past this roof. Unless the wall for the other unit’s 2nd story is wood-frame.. but I don;'t know. This is about where I was
You said it was spray foam. Good enough for me, I wasn’t there!
