Today inspection… Man!
Brilliant, will last forever!
Must have run out of copper pipe! I wonder what the kitchen aluminum foil is equal to in AWG…
Great idea, why waste money on fuses. (I see this a lot in industrial inspections)
Did you leave it out?
Hell No! I want the dump to burn down…
HAHAHAHA. Perfect.
Crazy, but is pulling fuse blocks part of the SOP?
I don’t care what the sop says… I pulled it.
I has ta knows… is that PVC beneath the AL??
Nope! It a fuse wrapped with AL foil.
Do you always pull a block or were you suspicious of something?
Yes! I do.
Its not very often you see that heavy of gauge of tinned copper.
Roy…is not in OHIO…
Yep! And glad of it.
