Originally Posted By: jschwartz1 This post was automatically imported from our archived forum.
Kevin:
The answer is no. Gas is odorless, so a chemical is added to it. This chemical reacts to copper causing corrosion. Galvanized pipe is required for gas.
Originally Posted By: kmcmahon This post was automatically imported from our archived forum.
That’s what I thought…but seeing this on fairly new construction (7 years) with copper piping from the gas meter to the furnace got me questioning myself.
Originally Posted By: wcottrell This post was automatically imported from our archived forum.
The gas codes use to allow copper or brass tubing if the hydrogen sulfide was less than 0.3 grains per 100 standard cubic feet of gas, then if the concentration of hydrogen sulfide was higher one must use tin lined copper tubing. Again AHJ is always the determining factor.
Hi to all,
Copper is suitable for gas supply line as long as it is type "K" piping which has a thicker wall that that used for plumbing and heating, it will be marked with its type printed in green on the tube but it is often difficult to read the labeling.
Picture (C) Inspection Depot, from the home guide Illustrations.
Originally Posted By: dbowers This post was automatically imported from our archived forum.
You need to check your local codes. We were using copper in Dallas in the late 70’s for the last 3’ or so of gas lines to furnaces or water heaters, etc. In Kansas City they used it on fireplace gas supply lines for the last 3’ or so before it joined up with black iron and entered the masonry firebox, up till just a few years ago. I’ve seen it installed in new construction as a connector (3’ line) between black iron and a furnace or a water heater in Asheville, NC just last year. Its used very commonly throughout the midwest for Propane Gas (LPG Tanks).
Some areas have never allowed it - BUT - the building codes and fuel gas codes permit the use of copper for gas under certain conditions (most of which are never/ever met). So to be 100% accurate don't tell people on our board its not allowed - it is. Maybe not in your town, but ........
Originally Posted By: Monte Lunde This post was automatically imported from our archived forum.
Jay
The statement " Galvanized pipe is required for gas." I have never seen Galvanized pipe used for a gas line. All I have ever see is black pipe and/ or Type K copper, but maybe in your neck of the woods Galvanized is being required instead of a choice of either Galvanized Pipe, Black Pipe or Type K Copper. I know Galvanized pipe is allowed but not in our neck of the woods (Supplier's requirements)
-- Monte Lunde CCI, CCPM, CRI
Viking Construction Services Inc.
